Closed
H110 in Phantom 410
THe phantom has 2 top mounted 140mm fans so can it fit the h110 in it, or should i get a h100i instead.
3 answers Last reply
More about h110 phantom
  1. NZXT website says:
    Clearance for top 240mm dual radiator for water cooling solutions
    http://www.nzxt.com/new/products/crafted_series/phantom_410
    So I guess H110 won't fit (280mm). Get H100i then.
  2. i wouldnt even bother with closed loop in the first place. low quality radiators and low quality pumps just wont cut it. id grab a good heatsink like the noctua nh-d14 or the phanteks equivalent if you are looking for asthetics
    if you have to get a closed loop cooler, get the swiftech h220 thats coming out by the end of the month. uses a pump 5x stronger than the ones on these asetek rebrands, copper fins vs the cheaper aluminum fins, and a much btter block
    http://www.swiftech.com/h220.aspx
    I agree with you, but the noctua doesn't have good aesthetics, that's the sole reason (that and size) that I don't like it. TBH I like the NZXT Havik 140, the phanteks is awesome as well.
Power Supplies Components
