Tom's Hardware > Forum > Digital Camera > Digital Point & Shoot > Fuji A205 DigiCam False Battery Low Indicator
Forum Digital Camera : Digital Point & Shoot - Fuji A205 DigiCam False Battery Low Indicator
Archived from groups: rec.photo.digital.point+shoot (More info?)
I got this camera brand new just a few days back. I've plunked in the
Panaonic alkaline batteries which came with the camera and within half
day or about the camera low battery light comes on. The camera at this
stage will auto shutdown believing the batteries are low. I was only
testing out the camera and maybe only took max 15-20 frames leaving
the LCD screen on. I did leave the batteries in the camera. The same
thing happened to another new set of EverReady alkaline batteries.
However I tried the same set of alkaline's on my walkman and the
walkman plays as if the batteries are new. I also tested the both sets
of alkaline "AA" using a multi-meter and they all tested good none of
them failed.
Can anyone suggest what I should do ? Has anyone seen a similar
problem ? Thanks for reading this post.
Sponsored Links
This is common behavior. The fact is that alkaline batteries don't work
well in digital cameras. Despite the fact that the batteries test well, and
work in other devices, after 15 to 20 pictures, they simply no longer have
enough power for most cameras.
It is best to look at alkaline batteries the same way as you regard one of
those "donut" spare tires...sufficient to carry you until you can get a
"real" tire. In this case the proper power for your camera would be a set
of NiMH rechargeable batteries of at least 1600 mAH. You should be able to
shoot at least 50 pictures per charge with these (although they may not last
as long as the alkalines in your walkman...the devices simply drain
batteries in a different fashion).
"The human adventure is just beginning"
"Tom Henry" <tom23499@yahoo.com> wrote in message
news:b72967b4.0412302221.36f93ea5@posting.google.com...
> them failed.
Reply to Bruce
Justín Käse wrote:
> In Message-ID:<b72967b4.0412302221.36f93ea5@posting.google.com> posted
> Invest in a set of NiMH batteries and a suitable charger.
>> problem ?
> Likely anyone that's played with a battery hogging digital camera.
Most seem to praise these items:
http://shop.mahaenergy.com/store/v [...] roduct=210
Frank ess
Reply to Anonymous
- 0 +
>>Has anyone seen a similar problem ?
Isn't this covered in the manual? My HP M407 manual advises using either
lithium single-use batteries or NiMH rechargeable. Smaller cameras use
smaller batteries, unfortunately.
Martin S.
Reply to MartinS
There are 1266 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
