Help from someone or from several people.
Ok, my first PC was and is a Dell Dimension 8300. It has died 4 times, and I replaced almost every part in it. The only upgrade I did was to put more ram in it.
I know just enough to maybe build my own PC which is what I want to try. I am tired of my DINO.
I know nothing about overclocking and all that wicked stuff, and I am too old (60+) to try to learn it. I just want to try an out of the box build. But I want it big enough and fast enough to handle anything I might throw at it.
I game some, mostly I use it for Photos editing, movies, video archives, things like that.
Most of the parts in the list I chose because of the reviews, and or what struck my fancy. The memory I know is overkill, but I want if for peace of mind. The case I think just looks cool, and I have to have it. Other than the case I will get everything from NewEgg because I like them.
Now can you tell me if all the parts I have picked are compatiable and will work, and if not what should I use in place of it.
Here is my pricey list. Not in any kind of order.
The case from Thermaltake
Thermaltake Level 10 GT Battle Edition
All these parts from NewEgg
SIIG JU-MR0A11-S1 USB 3.0 Internal Bay Multi Card Reader Panel
Item #: N82E16811996041
$39.99
Scythe Kaze Master Pro 5.25 Fan Controller
Item #: N82E16811998077
$44.99
Western Digital WD Green WDBAAY0020HNC-NRSN 2TB SATA 3.0Gb/s 3.5" Internal Hard Drive
Item #: N82E16822136772
$124.99
ASUS VK248H-CSM Black 24" 2ms (GTG) HDMI Widescreen LED-Backlit LCD Monitor 250 cd/m2 ASCR 50000000:1 Built-in Speakers&Webcam
Item #: N82E16824236261
$214.99
XFX Double D FX797GTDFC Radeon HD 7970 GHz Edition 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video ...
Item #: N82E16814150632
$469.99
ASUS Xonar Phoebus PCI Express x1 Interface Gaming Soundcard Set
Item #: N82E16829132054
$199.99
CORSAIR Professional Series Gold AX1200 (CMPSU-1200AX) 1200W ATX12V v2.31 / EPS12V v2.92 SLI Certified 80 PLUS GOLD Certified ...
Item #: N82E16817139014
$299.99
Cooler Master CM Storm Trigger SGK-6000-GKCM1-US Black USB Gaming Cherry MX Brown Keyboard
Item #: N82E16823129004
$109.99
RAZER DeathAdder Black 5 Buttons 1 x Wheel USB Wired Precision Optical Gaming Mouse - 3.5G Infrared Sensor
Item #: N82E16826153055
$48.99
CORSAIR Dominator Platinum 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMD16GX3M4A1866C9
Item #: N82E16820233305 (TWO SETS)
$329.98
$309.98
($154.99 each)
ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813131801
$329.99
Intel Core i7-3930K Sandy Bridge-E 3.2GHz (3.8GHz Turbo) LGA 2011 130W Six-Core Desktop Processor BX80619i73930K
Item #: N82E16819116492
$569.99
Microsoft Windows 7 Ultimate
Item #: N82E16832116718
$289.99
SilenX EFX-12-15 120mm Case Fan
Item #: N82E16835226042
$11.99
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel ...
Item #: N82E16835103099
$34.99
LITE-ON Black Internal 12x BD Combo SATA Model iHES212-08 LightScribe Support
Item #: N82E16827106451
$79.99
Intel 520 Series Cherryville SSDSC2CW240A310 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD) - OEM
Item #: N82E16820167088
$239.99
Kingston HyperX 3K SH103S3B/240G 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD) (Upgrade Bundle Kit)
Item #: N82E16820239050
$209.99
Tt eSPORTS SHOCK ONE Diamond Black DTS 5.1 Gaming Headset HT-SHO001EC
Item #: N82E16826254008
$74.00
ASUS Black Blu-ray Burner SATA BW-12B1ST/BLK/G/AS
Item #: N82E16827135252
OK, I know it is pricey, and I know it is overkill on some parts, but later I will add about 4 more hard drives for storage, and I may even someday want to go up to 64gb ram.
But will it all work, or am I just blowin smoke out my pipes.
Thanks all
EDISTORIVERRAT
$39.99
$44.99
$124.99
$214.99
$469.99
$199.99
$299.99
$109.99
$48.99
$329.98
$309.98
($154.99 each)
$329.99
$569.99
$289.99
$11.99
$34.99
$79.99
$239.99
$209.99
$74.00
Thanks all
EDISTORIVERRAT
