Are these parts compatible?
Here are the specs i want to use, can anyone say if they will work together alright? and if not can you recommend something that will?
GFX: Diamond Multimedia AMD Radeon HD 6870
CPU: Intel Core i5
RAM: AMD Performance 8GB
HDD: Seagate Barracuda 2TB 3.5"
motherboard: Gigabyte H77M-D3H LGA 1155 Motherboard
Thanks in advance, Noah
15 answers Last reply
More about parts compatible
  1. Not sure about the RAM it wasn't specific enough also Make sure the i5 CPU you get is LGA 1155 though, not sure if all of them are.
    Other than that you're good.
  2. Since you don't mention what i5 cpu or what ram, can't tell you if it's compatible or not.
  3. Oh here,
    CPU:Intel® - Core™ i5-2500K Quad-Core 3.3GHz Processor
    RAM: AMD Performance 8GB (2 x 4GB) DDR3 1600MHz Desktop Memory
    And possibly this instead of the i5
    2nd Gen Core i7-2600K 3.4GHz (3.8GHz Turbo)
  4. Yes, they should all be compatible
  5. Why an H77 board?
  6. No reason just picked one that worked for me, mostly i wanted the crossfireX support, other than that i just picked it so that Intel processors work.
  7. Aim for Z77.
  8. Why, like i mean whats better on it? I'm building for the first time so i dont know whats what.
  9. H is lower end, Z is top of the line.
    Price difference: $20.
  10. Oh btw will this PSU be able to handle all of that?
    Apevia 650W Computer Power Supply
  11. Gosh, get rid of that POS.
  12. What would you suggest for the Power supply?
  13. Is this a better one? Thermaltake 700 W Computer Power Supply (TR700)
  14. amuffin said:
    Aim for Z77.
    +1 or Z68 if you can't afford Z77
  15. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
New Build Systems
