Solved
Are these parts compatible? [correct forum]
Last response: in Systems
Are these parts compatible? looking to build.
specs:
GFX: Diamond Multimedia AMD Radeon HD 6870 Video Card
CPU: Intel 2nd Gen Core i7-2600K 3.4GHz (3.8GHz Turbo) (or a i5)
PSU: Thermaltake 700 W Computer Power Supply (TR700)
RAM: AMD Performance 8GB (2 x 4GB) DDR3 1600MHz Desktop Memory
HDD: Seagate Barracuda 2TB 3.5" Desktop Internal Hard Drive
CASE: Cooler Master Full Tower Desktop Computer Case
Motherboard: Gigabyte Z77-D3H LGA 1155 Motherboard (GA-Z77-D3H)
Best solution
They are compatible, but I recommend msi video cords, xfx or corsair PSU's, and ivy bridge processors. However, you didn't ask for suggestions, so I won't go into detail.
Should be, yep.
Though with that sort of budget, I highly recommend getting an SSD as a boot drive - it's seriously mind boggling. As Tom's said recently, it's just about the biggest upgrade you could do to a modern computer.
Related ressources
DarkSable said:
Should be, yep.
How much does windows 7 ultamate 64 need space wise
Ask the community
