Why is my 690 running DX10??
I finished building my new rig last night, woke up this morning to start a million different downloads and updates and I happened to notice something that showed my 690 running DX10...shouldn't it be at 11? Thanks for the help
Hunt
Hunt
More about : 690 running dx10
Related ressources
- 8600GT benchmark with lost planet DX10 - Forum
- New laptop. gt 540m is underperforming? Also dx10 issue... please help - Forum
- Running DX11 on a DX10 GPU?? - Forum
- Anybody heard of gtx 690 running on older 775 platform? - Forum
- DX10 games are out, and I'm running them all under DX9... - Forum
huntrik said:
windows experience indexDon't be confused by the graphics engine used to test something and what the card is capable of. If they use a DX 10 graphics engine to test, it'll show you are running in DX10 mode. If you play The Witcher 2, it'll show you are in DX9, but when you run Metro 2033, and set it to DX11 settings, it'll show you in DX11.
You don't need ot to run at 4.2 all the time it will throttle up and down depending on the load. So if you are running something(s) that is cpu intensive the cpu will throtte up to meet demand, also if the system is idle or not using much cpu time it will throtle down to conserve power and produce less heat.
huntrik said:
The #1 in the Hall of Fame section is the only one with a score over 15k on a single 680...Yes I ran it in performance modeWhat is the rest of your system? The test also tests your CPU, which is how they get that high of a score, the single GPU score would still be lower than my SLI 680's, but their physics scores take them up that high along with a high OC on the GPU.
GRAPHICS CARD
Graphics Card
NVIDIA GeForce GTX 690
VendorEVGA Corporation# of cards2SLI / CrossFire On Memory2048 MBCore clock705 MHzMemory clock3004 MHzDriver nameDriver version8.17.13.142Driver statusFM Approved
GRAPHICS CARD (SECONDARY)
Graphics CardIntel HD Graphics 4000VendorUnknown# of cards2SLI / CrossFire On Memory0 MBCore clock0 MHzMemory clock0 MHzDriver nameDriver version8.15.10.2696
PROCESSOR
Processor
Intel Core i5-3570K Processor
Processor clock2884 MHzPhysical / logical processors1 / 4# of cores4
GENERAL
Operating system64-bit Windows 7 (6.1.7600)MotherboardASUSTeK COMPUTER INC. SABERTOOTH Z77Memory16078 MBHard drive model128GB SAMSUNG SSD 830 Series ATA Device
DETAILED SCORES
3DMark ScoreP13036Graphics Score16979Physics Score7719Combined Score7632Graphics Test 179.63 FPS Graphics Test 281.89 FPS Graphics Test 3106.35 FPS Graphics Test 449.97 FPS Physics Test24.51 FPS Combined Test35.5 FPS
SETTINGS
Default settings used Yes EditionBasicScreen Width1280Screen Height720Msaa Sample Count1Texture Filtering ModeTrilinearMax Af Anisotropy1Tessellation Detail5Max Tessellation Factor10ShadowMapSize5Shadow Cascade Count4Surface Shadow Sample Count16Volumetric Illumination Quality5Ambient Occlusion Quality5Depth Of Field Quality5Enable Window ModeOffEnable Vertical SyncOffEnable Triple BufferingOffEnable WireframeOffColor Saturation100%
Graphics Card
PROCESSOR
Processor
GENERAL
DETAILED SCORES
SETTINGS
huntrik said:
Just hit a 13036 after fresh install of video driver and setting the BIOS to the factory OC settingI'm assuming that's the 13036P score. That is a lot better and closer to what I'd expect.
When I asked for a break down of the score, I mean the combined score, graphics score and physics score.
PROCESSOR
Processor
Something doesn't look right here...aka 2nd GPU and 2884mhz
PROCESSOR
Processor
Related ressources:
- ForumAGP DX10 card running at 1280X720. Are resellers here.
- ForumPICS of dx10 ruby demo ( running on 2900XT)
- ForumWhy I think I must get a DX10 card when I get Vista...
- ForumSomeone tell me why DX10 wont work on a 1900xtx
- ForumSli Gtx 580 / 690 / Titan , need advices
- ForumGTX 690 V GTX Titan
- ForumGtx 680 SLI v GTX Titan v GTX 690
- Forum2x 680 vs. 690
- ForumUpgrading advice /w i5 3570k + gtx 690
- ForumGtx 690 or Gtx Titan for surround
- ForumGTX 690 2560*1440 Low FPS
- Forum[New Build] Micro ATX GTX 690
- ForumNo POST with new video card
- ForumGtx 690 no sli option
- ForumWhy doesn't my graphics card work!?
- More resources
