Is the power supply gonna fit in cm haf x?
11 answers Last reply
More about power supply gonna
  1. it will fit w/o a problem ;)
    you will be fine...
  2. zcosmin said:
    Yes, it will fit even in mid tower haf x.
    Some haf x are full tower, some are mid tower,
    which haf x model do you have?
    full tower haf x case, sorry for not mentioning, if it doesn't fit then can you recommend me a good powersupply from scan.co.uk 1050w hybrid modular which will fit in a full tower haf x case pleasE? thanks
    you are getting confused between
    CM Haf X ----> Full Tower
    CM Haf XM----> Mid Tower
  5. Are you sure you actually need a 1050W PSU? It's a lot of power. Assuming you are correct, best thing I can find on scan is this-
    http://www.scan.co.uk/products/1050w-xfx-black-edition-p1-1050-bfuk-full-modular-80-plus-gold-90-eff-eps-12v-1-x-135mm-fan-atx-v22-
    Cheaper than the Corsair, full modular, made by Seasonic.
    you will be fine...
    +1
  7. Thanks guys i will go with http://www.scan.co.uk/products/1050w-corsair-pro-series-hx1050-hybrid-modular-80-plus-gold-90-eff-eps-12v120mm-fan-atx-v231 since its a trusty company ;) thanks guys. Just to confirm the corsair 1050w hx1050 hybrid modular will fit into a coolermaster HAF X FULL TOWER case
    Thanks
    Oh, it'll fit was just curious. The width & ht of these ATX PSU's is the same,
    length can differ.
    Was curious like other posters of what you are running to req
    +1khz psu. You running 3 7970's or 3 680's?
  9. ill be gettin 2 680s,
  10. Those PSUs should be good for up to 3 GTX680s. I'd still recommend the XFX over the Corsair though.
  11. GeForce GTX 680 - On your average system the card requires you to have a 550 Watt power supply unit.
    GeForce GTX 680 SLI - On your average system the cards require you to have a 750 Watt power supply unit as minimum.
    If you are going to overclock GPU or processor, then we do recommend you purchase something with some more stamina. http://www.guru3d.com/articles_pages/geforce_gtx_680_review,9.html
Power Supplies Cooler Master Cases Components
