Hey guys, so first off Im not a n00b, Ive built systems before, but this time I have become unstuck.
Here is the spec
AMD Athlon Phenom II x4 965 Black Edition CPU (with Stock cooler)
Gigabyte GA970A-UD3 Motherboard
Corsair Vengance 1600Mhz Dual Channel 8GB RAM
Coolermaster GX LITE 700W PSU
ASUS HD6670 Radeon Graphics Card
Corsair Force 60GB SSD
Seagate Barracude 1TB, 7200rpm, 64MB Cache HDD
TP LINK Wireless lan card 802.11b/g/n
2 x SAMSUNG DVD drives
CASE : Phantom 410 Mid Tower
Problem : the pc is completely unresponsive, I plug everything in and press the start button but nothing, its like the motherboard isnt even getting power to it
UPDATE : THEN about 5 minutes ago, I changed the PWR_FAN connection by moving it to the left one place, there are 3 pins on the PWR_FAN connection on the motherboard but 4 holes in the connector for the PSU, and now it starts for a split second then dies.....soooooo I dunno....
So far I have tried this
http://www.tomshardware.co.uk/forum/261145-13-read-posting-boot-video-problems.
Checking my POWER SW / RESET SW etc are correct way round.
Checking standoffs.
using alternate power cables.
using alternate mains sockets.
using alternate 2x4PIN power connectors for 12v ATX CPU connector on motherboard.
Double and triple checking everything is tight and pushed in.
Ive also checked the manuals to make sure I did everything correctly.
Checking for short circuit
after I had the problem I removed everything and re installed in accordance with the forum guide above, but still no joy.
Please help, as I am building this for a friend and I have already bought the parts myself. any suggestions would be appreciated
Kind Regards
Phil
Here is the spec
Checking standoffs.
Kind Regards
Phil
