Will this power supply be enough for this computer spec?
Hey,
I was wondering if this power supply:
SeaSonic ECO 500W Active PFC, 2X PCI-E 6/8, 34A / 12V Single Rail 220V Only
Will be good enough for a few years with the following computer specification:
CPU -Intel Quad-Core i7 3770 3.4Ghz HyperThreading 8MB Tray
CPU Cooling - ZALMAN 8000T PLUS SI EDITION
Motherboard - Gigabyte GA-H77-DS3H
Case - Fractal Design Define R3
RAM - 2xCorsair 8Gb CMX8GX3M1A1600C11 CL11
HDD - Seagate 2TB, 3.5", SATA3, Barracuda 7200.14
SSD - Samsung 120GB 2.5" SSD 840 Series
GPU - MSI GTX660 TI 2GB HDMI OC EDITION
Thanks a lot!
7 answers Last reply
More about will power supply computer spec
  1. Yes, for a 660 ti, it's recommended a 450W psu and with 24A on it's +12V rail, you have a quality psu with 34A, so it will do, the i7 has a low power consumption.
  2. hapl0 said:
    Hey,
    Thanks a lot!
    LOL - dj beat me to it
  3. Thanks for the quick reply...
    Do you think it will last for a few good years? (Let's say, 5 years?)
    Also, if something did happen to it, how likely will it ruin other computer parts?
  4. It's a quality psu, it will last, but how long nobody knows, it has its protections in case the psu start to fail, no need to worry.
  5. Alright! Thanks again, you've been helpful :)
  6. Does that Seasonic SS-500BT OEM power supply have any PCI Express supplementary power connectors?
    You need at least two 6-pin PCI Express supplementary power connectors for the GeForce GTX 660 Ti graphics card.
  7. The psu has two 6+2-Pin pcie connectors.
Power Supplies Components
