PC to TV connection problem, no signal using vga
  • Graphics Cards
  • TV
  • Connection
  • Computer
  • Boot
  • VGA
  • Graphics
August 12, 2012 5:02:52 AM
I hooked up my computer to my TV,when i boot up it show on the TV,but then TV goes to no signal,whats wrong??????
More about : connection problem signal vga
a b U Graphics card
August 13, 2012 6:56:05 PM
The resolution is not supported by your TV. Hook up a monitor, load into windows, change the desktop properties so the resolution is 800x600, then try again with the TV. You can adjust the screen to a better resolution once you are in windows.
m
l
