Hi,
I just bought the Creative Sound Blaster Recon3D Fatal1ty Champion sound card.
Now I have very annoying noise (5.1 speakers and headphones). I tried swapping the slot of the audio card, no difference. The noise is louder when I use the front panel jack. I also disconnected the front panel, but still there was noise from the card. The noise is also a lot louder when using my headphones (Razer Electra) then when I'm using my headset (Steelseries Siberia v2). There is no noise whatsoever when using onboard audio.
Is there anyone who can tell me how to fix this? It was an expensive card and I want to use it!
Thx
Thx
