Graphics Card Purchase Help
Hello, I'm in a bit of trouble while trying to buy a new graphics card.
Essentially my problem is that I use two different set-ups; one with dual monitors using 2xVGA to DVI adapters and at other times using 1xVGA to DVI adapter and 1xHDMI Cable.
I was just about to purchase a graphics card , the Radeon HD6950, when I realised that It cannot be used with my first setup (the two VGA to DVI adapters).
Essentially; I am looking for a graphics card for £150-200, preferably AMD, that will be able to be used in both of my setups.
Any help is greatly appreciated,
thanks
1 answer Last reply
More about graphics card purchase help
  1. In other words you want a video card w/ 2 DVI outputs and 1 HDMI output.
    You wanna use adapters to plug two existing VGA monitors into one (dual) DVI video card. And you wanna plug your home theater screen into the HDMI output, of same card.
    This is a card that drives 3 screens. You can move anything from the main screen to either of the other 2 screens, etc...you will see. It's confusing at first, but not difficult to master.
    And so this depends on your motherboard.
    Yes, you must go to the motherboard manufacturer, and find the list of compatible video cards.
    Your card has 2 DVI outputs, and 1 HDMI output. The more expensive, the better.
    Actually there are a huge range of prices, depending on your approved card list.
    But generally spend more and get more.
Radeon Graphics Cards Dual Monitors DVI Graphics Product
