S Silentseraph Honorable Feb 13, 2013 22 0 10,510 Feb 16, 2013 #1 I just got a modular power supply. There's a cable that has 3 connectors that go into the harddrive and CDROM drives. Is it ok if use one cable and connect both at the same time or do I have to use 2 separate cables to connect the peripherals?
ihsaan96 Honorable Dec 1, 2012 615 0 11,060 Feb 16, 2013 Solution #2 You can use the same cable for both. Upvote 0 Downvote Solution
S Silentseraph Honorable Feb 13, 2013 22 0 10,510 Feb 23, 2013 #3 Best answer selected by silentseraph. Upvote 0 Downvote
