i recently purchased an older Dell Optiplex 320 with the intention of using it as a budget friendly (and quiet) media center.
my television only has a vga input that is paired with an audio input from the PC.
my issue is that the graphics card (i cannot remember the specs on it, but i believe it's irrelavent currently) does not display properly using a vga connector. this card is an SFF card with a dms59 connector. i first plugged in the dual DVI adapter and it works flawlessly. i then plugged in a DVI to VGA adapter and i lost (what i believe to be) the red signal as everything onscreen is tinted green. i tried another DVI to VGA adapter and received the same results. i then connected my monitor to the machine using the same VGA adapters and i get the same result.
i then acquired a dual VGA DMS59 adapter and am getting the same results. as i am not all that savvy with video pin-outs, i am curious if anybody might have a clue as to why this is happening. i am having a problem believing that two DVI to VGA adapters and a DMS59 to dual VGA adapter are all "broken". also, since there is a DMS59 to dual VGA adapter, i'm sure that the card is capable of using the older technology.
so, unless somebody has some opinions or thoughts on this, i'm thinking about one of two things.
1. getting another SFF card
2. getting a DVI to HDMI cable that will transport audio from a 3.5mm plug over the HDMI cable (do they even make such a thing?
thanks in advance!
thanks in advance!
