BSNL Honorable Jul 15, 2012 404 0 10,780 Aug 13, 2012 #1 as i am buying sapphire radeon hf 7750 1gb ddr5, will i have to buy a new cable also?
nikorr Champion Oct 22, 2009 23,335 0 54,960 Aug 13, 2012 #2 Any of them can be reused. What do u have already? HDMI? Use that. 1 x HDMI 1 x DisplayPort 1 x DVI Upvote 0 Downvote
BSNL Honorable Jul 15, 2012 404 0 10,780 Aug 13, 2012 #3 nikorr : Any of them can be reused. What do u have already? HDMI? Use that. 1 x HDMI 1 x DisplayPort 1 x DVI http://images17.newegg.com/is/image/newegg/14-102-969-Z02?$S300W$ no, now it is connected with dvi(cpu)to dvi(monitor). will i have to buy a new cable if i buy that graphics card? Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 Aug 13, 2012 #4 I mean, what cable do u have now? DVI- reuse it. Its fine. DVI is as good as HDMI. Upvote 0 Downvote
BSNL Honorable Jul 15, 2012 404 0 10,780 Aug 13, 2012 #5 nikorr : I mean, what cable do u have now? DVI- reuse it. Its fine. DVI is as good as HDMI. so that means i don't have to buy a new cable? Upvote 0 Downvote
BSNL Honorable Jul 15, 2012 404 0 10,780 Aug 13, 2012 #7 nikorr : No. Keep it. my monitor does not have a hdmi port on my monitor ,so it will be better to connect the dvi(video card)to dvi(monitor) ports. Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 Aug 13, 2012 Solution #8 That's as good as it could be : ) Upvote 0 Downvote Solution
BSNL Honorable Jul 15, 2012 404 0 10,780 Aug 13, 2012 #9 nikorr : That's as good as it could be : ) and is there any software to determine the clock speed,version(ddr3 or ddr5)and the memory of the graphics card when i will install that sapphire radeon hd 7750 1gb ddr5. the shopkeeper can also bargain with me. Upvote 0 Downvote
BSNL Honorable Jul 15, 2012 404 0 10,780 Aug 15, 2012 #10 Best answer selected by BSNL. Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 Aug 15, 2012 #12 This topic has been closed by Nikorr Upvote 0 Downvote
