Hello, I am going to build a gaming pc on a budget. My journey started about 2 weeks ago when my laptop fell out of my bag on my way to a lecture and smashed ito thousands of pieces. After sccoping up the remains and binning them (luckily all my work was on a flash drive!) I then began to consider what I was going to do about a new machine.
The main purpose of course, is gaming. The main games I a interestedin are Empire and Napoleon Total war (and future total war titles) and the rcent Guild Wars 2.
I've copied the guildlines to this sort of thread below:
Approximate Purchase Date: within the next month
Budget Range: between £500-£600
System Usage from Most to Least Important: Gaming, interent research, uni work.
Are you buying a monitor: Yes but thats not included in the budget.
Parts to Upgrade: (e.g.: CPU, mobo, RAM) **Include Power Supply Make & Model If Re-using**
Do you need to buy OS: Yes. So far I think Windows 7 is my only option due to the games?? I don't know if for example Linux can play games?)
Preferred Website(s) for Parts: cheapest?
Parts Preferences: I don't know?
Overclocking: If it's possible?
SLI or Crossfire: Neverheard o it?
Your Monitor Resolution: Whatever is best to play the games in high setting?
Additional Comments:be nice for it to be quiet? not to bothered as its staying in my living room.
And Most Importantly, Why Are You Upgrading: old laptop smased....i want a desktop now to play games mainly.
List of pats I have selected so far (this is what I need help with...will thy work wll together? Are they compatible? Will they lay guild wars in highest setting?
Motherboard: Gigabyte GA-H61MA-D2V Intel H61 LGA1155 DDR3 Motherboard
http://www.advancetec.co.uk/acatalog/Gigabyte-GA-H61MA-D2V-Intel-H61-LGA1155-DDR3-Motherboard.html#a150733
Case: Blaze Case Black/Red no PSU
http://www.microdirect.co.uk/Home/Product/54128/Blaze-Case-Black-Red-no-PSU
CPU: Intel CPU Core i7 2600K Sandybridge LGA1155 Retail boxed with cooler (3yr Manufacturer's Warranty)
http://www.microdirect.co.uk/Home/Product/50065/Intel-CPU-Core-i7-2600K-Sandybridge-LGA1155
RAM: Corsair memory 4GB XMS3 Kit (2x2GB) DDR3 1333MHz 240 pin DIMM Unbuffered 9-9-9-24 RAM
http://www.microdirect.co.uk/Home/Product/44709/Corsair-memory-4GB-XMS3-Kit--2x2GB--DDR3-1333MHz
PSU: Coolermaster PSU 600W GX Lite (This i one I'm not sure about, how do you know ow much Wattage you actually need??)
http://www.microdirect.co.uk/Home/Product/54360/Coolermaster-PSU-600W-GX-Lite
GPU: VTX3D 2GB Radeon HD 6950 (I have no idea about GPU's!?)
http://www.microdirect.co.uk/Home/Product/52999/VTX3D-2GB-Radeon-HD-6950-with-Dirt-3-game
Other things I haven't considered....sound card? mouse, keyboard, additional fans?
Apart from all that is there anything I have missed? I hope the post is not t 'lengthy'.
Thank you
Thank you
