So, this is a lesson in why you should never get so comfortable tinkering with your computers that you start doing things like watching TV while installing a new CPU cooler.
I was swapping out my old 92mm IceEdge 400XT tower for a new Xiagmatek Gaia 120mm cooler on my Dell Inspiron 570 mobo that runs a Phenom 965 @ 4.3ghz and was obviously overwhelming the smaller cooler. Well I was watching a movie and doing the swap without any real thought. Before I knew it, I had the backplates swapped and had a perfectly even spread of AS5 on top of the chip... it seemed almost too easy as I tightened down the tower and closed the case.
Yep, it was too easy. If I'd taken the time to LOOK at the bottom of the cooler, I would have seen the plastic sticker protecting the contact surface. I tried starting the computer probably five times without any image on the monitor or beeps coming from the machine. I actually got confused enough to jumper-clear the BIOS and restart it. There was a long series of beeps that I couldn't make any order out of, and still no picture. I jumpered the bios once more, got it to start BIOS, but then blue screened and shut down. At that point I realized what I might have done- I checked and sure enough, the plastic was between the cooler and the chip. Nothing melted, no signs of damage on the board I could see. I removed the plastic, got the thermal paste ready again, and installed it again after clearing BIOS. I can get it to
Now I can get the computer to turn on only when I use the BIOS jumper first. At that point, I can either 1) go straight into windows and either stall at the loading screen or immediately after the desktop opens, or 2) go into BIOS and set the system up correctly, save and exit.... and then see NOTHING happen. If I restart without resetting the BIOS jumper first, nothing happens except the fans spinning up.
I am assuming there are three possible scenarios I am facing. First and best, only the mobo might be gone. I wouldn't be devastated there. Second and pretty bad, I ruined the CPU alone from heat. This would be bad, especially since I can't upgrade past the X4 965 with the Dell BIOS, so there wouldn't even be the cool "excuse to upgrade" silver lining. Third, the real nightmare, would be that I fried possibly the board/cpu PLUS any of the other components like the memory, SSD's, or even shorted the PSU.
Plan today is to move everything into other systems to test individual parts, but any hints on what I am likely facing?
