I have a fractal design 1000 micro atx case, with a 120mm fan at the front bring air into the case, a 80mm fan on the rear bringing air out of the case and a 120mm on the side bringing air into the case.
Now, my problem is, the 120mm fan on the side of the case was the one I added on last (order was 120mm at front, then 80mm on rear, then 120mm on side.) And it is bringing air into the case, however, I have not noticed any changes in temperatures for my components like my GPU, should I change it to bringing air out of the case? Thanks.
