Hey guys, I've been browsing this site for awhile and it seems like everyone is quite helpful when it comes helping another person out. I would like your help/opinion on the build I've posted below. I would be really appreciative if you guys can weigh in on your opinion if there is something wrong or something better for the build.
Approximate Purchase Date: Next month
Budget Range: 1300 US after rebate, before shipping. If needed, I can probably add another 100 or so if you deem it fit.
System Usage from Most to Least Important: Games is the highest priority
Are you buying a monitor: No
Do you need to buy OS: Yes
Preferred Website(s) for Parts: I don't know many computer website but any is fine.
Parts Preferences: No preference, as long as it has great performance and is reliable
Overclocking: Maybe
SLI or Crossfire: Maybe
Your Monitor Resolution: 1920x1080
Additional Comments: I wouldn't mind a quiet PC but who wouldn't right? Though it doesnt bother me much but it would be nice.
And Most Importantly, Why Are You Upgrading: My last PC is 5+ years old and I think its time to upgrade. I would like to finally be able to experience games like it was meant to be instead of trying to play games at the lowest possible settings and turning all effects off. Overall, just to have a faster PC.
Here is what I've researched so far. This build does not have a case, so if you can suggest some, that would be great.
PCPartPicker
Again, your help and opinion on making this build better is really appreciative.
Thanks for your time!
Overclocking: Maybe
PCPartPicker
