Help Deduce and Identitfy High Pitched Noise
  • Power Supplies
  • Components
Last response: in Components
February 18, 2013 11:24:44 PM
Toms Community,
I've been trying to isolate a high pitched noise eminating from my system:
Here are my specs:
PC Power and Cooling Silencer Mk III Series 400W Modular Power Supply
i7 2600 (Non-K)
Dell OEM 1155 Motherboard
16GB 1333 Corsair Ram,
1TB Hitachi (Or formerly Hitachi) Deskstar 7000.C
EVGA 660 Signature 2
LG Blu-ray Drive
Fractal Design R3 Case.
Its a high pitched noise that is definitely noticable. Started about 3 weeks ago, been doing the component ballet for a while. At first I thought it was my 6850 GPU. I was planning on upgrading anyway so I plopped in a GTX 660. No change. Then I thought it was a new samsung f3 spinpoint I had put in. Pulled it out and replaced with the above with zero change. My next course of action is to get a paper roll core and literally hold it up to the components and listen.
One thing that I have noticed is the buzzing will cease whenever I scroll through something, like my steam games list. Just for the moment spent scrolling. Bizzarre.
Here are my suspects:
PSU (Good PSU, about a year old, has the amperage to handle my system.)
Motherboard (DELL motherboard manufactured by who knows, bad capaciter?
Let me know what you guys think.
Thank you.
More about : deduce identitfy high pitched noise
February 19, 2013 1:50:46 AM
The only things that make noise inside a computer are fans and the hard drive. So it has to be one of those, I would try unplugging every fan until the noise doesn't happen anymore and if it still does, it is most likely the hard drive disc(s).
m
l
February 19, 2013 1:53:56 AM
Thanks for the reply but the hard drive has already been changed out. The odds of two drives producing the same problem aro astronomical.
m
l
