Archived from groups: alt.cellular.nokia (More info?)
I have an Nokia HDW 2 Bluetooth headset.
Everything works on it but there is no sound from it.
It has worked since May until last week.
Have tried everything from resetting it, removing the battery and
disconnecting it from the phone (Nokia 6310i)
I bought it in the USA in May 04 so I called Nokia thinking it would be
covered by the warranty.
Nokia said that there is no warranty agreement between Nokia UK and Nokia
USA.
Am I fighting a lost cause and should I just go out and buy another one.
Any help or advice would be useful.
