Approximate Purchase Date: this weekend for some of the parts at least
Budget Range: 600-800 (without monitor or graphics card)
System Usage from Most to Least Important: mostly for media PC (hooked up to my 50" TV), but I would like to be able to play games on it (Star Craft 2, CS: Global Offensive, Diablo 3)
Are you buying a monitor: No
Parts to Upgrade: Pretty much everything, my last build was 8+ years ago
Do you need to buy OS: Yes
Preferred Website(s) for Parts: newegg.com
Overclocking: Maybe
SLI or Crossfire: Probably not, at least not in the near future
Your Monitor Resolution: 1920x1080 for my 50" HDTV
Additional Comments: quiet would be nice (it will be used a lot for Netflix, watching movies, etc), and also I am looking for it to be flexible and upgradeable in the future.
And Most Importantly, Why Are You Upgrading: I've been using my laptop, and it just can't handle the TV at really high resolution.
Parts so far:
(1) CPU: Intel i5-3750K - $230
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
(2) SSD: Samsung 830 Series 128GB - $100
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147134
(3) Memory: Corsair Vengeance 8GB (4GBx2) - $37
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
(4) CPU Cooling: COOLER MASTER Hyper 212 Plus - $30 ($20 after MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
(5) OS: Windows 7 Home OEM - $100
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
(6) Case: Antec Three Hundred ATX Mid Tower - $40 (weekend deal on Newegg)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
Total: $537 so far
Need advice on what to get for MOBO and Power Supply. I'm leaning towards not getting a video card for now and picking one up for Christmas or Black Friday. It is only a couple months and from what I've seen the integrated graphics (HD 4000) can get me by until then.
MOBO - I want reliabile and upgradeable. At least one or two USB 3.0 ports, a couple spots for SATA 6GB/s. Maybe the ASRock P67 Extreme4 for $140? Or is that excessive for what I need?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157265
Power Supply - main thing is very reliable and powerful enough for what I've listed above. Also at least somewhat quiet (not sure if it really adds much noise or not).
Also any comments on my choices above would be great. Especially any problems with compatibility, but I think that would more depend on the MOBO. Thanks in advance!
Overclocking: Maybe
Parts so far:
Total: $537 so far
