Need some help building a system!
Hey guys. I haven't upgraded my PC in quite a few years. I'm currently running an Asus Crosshair motherboard, X2 6400+ BE CPU, Radeon HD 4850 video card, and 4 GB of DDR2 memory. I know... It's ancient. Have your laughs haha. I just bought a nice HD LED smart TV and I would like to be able to run HDMI cable from the output on a video card to my TV to watch HD movies. Unfortunately, my video card doesn't even have an HDMI output. I don't play very graphical intensive games anymore, but if I made the upgrade, I would probably get back into it. I am basically looking to upgrade the motherboard, CPU, video card and RAM. I've been out of the loop for a long time, but I'm thinking of sticking with an AMD system, just because of the price factor. Just finishing college, it's tough right now. I was looking at the FX-8120 CPU and maybe a Radeon 7850 video card. Any suggestions on whether this would be a good setup for me, or if it would be more than I need? If so, what motherboard should I go with? And I'm assuming I'd need DDR3 memory? I'd like to try keep each component in the $100-$200 range, but I'm open to all advice! Please help me out guys! Thanks.
12 answers Last reply
More about need building system
  1. Could you please fill this out?
    In any case, should your budget be about $850 check my build out here:
    And if you need a build more than that, check out my $1000-1100 build here:
    the FX-8120 is probably the worse choice just because almost all Sandy Bridge/Ivy Bridge chips mop the floor with it. Expecially in gaming. The 7850 is decent but I think with optimization you can do better.
  2. Approximate Purchase Date:
    Within the next month.
    Budget Range:
    $100-$200 per component.
    System Usage from Most to Least Important:
    Internet browsing, gaming, streaming HD movies to TV.
    Parts Not Required:
    Monitor, speakers, HDD, CD Drive, power supply, case, wireless card.
    Preferred Website(s) for Parts:
    No preference.
    Parts Preferences:
    HDMI output with solid HD video streaming to my TV, running newer games on high graphics.
    Probably not, but maybe a slight overclock.
    SLI or Crossfire:
    Monitor Resolution:
  3. So if I wanted to go with an AMD CPU, which one should I choose? Or is it not even worth it?
  4. AMD route isn't even worth it at this point:
    i5 2500K vs FX-8150
    Intel wins out almost every time. And with that said check out my build guide. Again, the $850 or $1000 would probably fit you.
  5. Trinity APUs may be worth checking if he's on a budget.
    @Bedwards923 - Please give us your total budget, not budget per component since.. that doesn't really help. :P
  6. ^ I don't think he was though, his budget seems pretty large?
  7. I'm gonna say $600-700.
  8. ^I would say that's pretty tight.
  9. ^ Not quite, he doesn't need a PSU, HDD or Case.
    Check out my $850 build here:
    Puts the total at ~$630 w/o the HDD, PSU, and Case.
    Should be a solid build for you. Way better than an AMD cpu build.
  10. Oh, I missed that.
    Yeah, an Intel build would be good for now.
  11. Thanks guys!!
  12. No problem! Good luck!
New Build Graphics Cards Motherboards Systems
