Graphic Card Swap Help
Alright, So basically I have a Few years old Computer that i'm using for a while now, The Problematic is the Video card:The one and only Nvidia MSI 9500GS (Low end)i have to run games at 1024x768 on lower and it laggs.So My Question is : What Best Video Card I can get with my current Spec, considering i just want to put money on a card, and no other piece.My Power Supply is a '' HIPRO 350 Watt '' My big main Problem is that the case is Really small , its a HP Pavilion a6752f that i bought in 2008 or so the Dimensions are :
9.6 x 6.9 x 16.3 inches
Motherboard : PEGATRON CORPORATION Benicia
CPU: Intel core Quad Q8200 (2.33ghz)
Actual GPU: Nvidia MSI 9500GS
RAM: 4Gb DDR2 400mhz
OS: Vista Home Premium 64Bit SP2
so my Question is Can i run basic 500 Series with my case or i need a '' low profile card '' ?
Here is a pic of the back and what i mean, it seems to only use like a slot, and the 550ti seems larger, Would it fit ?
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=41125&Sku=E145-0550 Evga 550ti
Do you guys have ideas of what kind of Card i could Put in there considering the case and that i want to RUN Newest games like Bf3, Ghost Recon, Max Payne and other Graphics-intensive game ?
I don't want to change the power supply of 350w BUT, if i really need to, i have like a budget of 150-200$ max For both videocard and Power supply
6 answers Last reply
More about graphic card swap help
  1. If you go for that GTX550ti I do advice you to grab a new PSU of atleast 400W.
  2. But is the 550ti Would fit ? My case seems to use single slot cards only
  3. Well the 9500 GT is 6.875 inches long (Couldn't find any specs on the 9500 GS cause it's an OEM card, but it's based on the 9500 GT so I'm assuming the same size). The GTX 550ti is 8.25 Inches long. Does it look like there is an extra ~1.5 inches of clearance in your case?
    And you definitely need a new PSU if you are going to upgrade. Antec, Seasonic, Corsair, PC Power & Cooling, XFX, and Enermax all make good PSUs.
  4. 9600GT/Radeon 6670, maybe. Though i'm leaning towards the 6670. This is if you'd want to avoid buying a PSU.
    Otherwise 550 Ti/Radeon 6770/9800GT would do fine with a 400-450w PSU.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814121442
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130534
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814150560
  5. Thanks For the reply, Really useful. I figured out a Full card would work.
    And for the Power supply Im thinking of getting this
    http://www.amazon.com/Cooler-Master-eXtreme-Supply-RS500-PCARD3-US/dp/B001G0WPLK/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=2H363AXGW4SX2&coliid=IXXX54UVMOJ5A
    With The Radeon HD 7750 1GB
    http://www.amazon.com/HIS-H775F1GD-Displayport-Express-Graphics/dp/B007827196/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=2H363AXGW4SX2&coliid=ISA5DUVXSXWRS
    http://www.amazon.com/Sapphire-11202-00-20G-Radeon-PCI-Express-Graphics/dp/B007B5V614/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=2H363AXGW4SX2&coliid=IV7MGIV0EGL92
    I heard Good Feedback, Main reason is it doesnt need much power, And i do not Need auxiliary power. Can Someone just tell me if the PSU would Handle it and that its not TOO crappy ?
  6. I think the 7750 would probably be a good fit for you (unless you wanted to try the 7770). Check the back of your PC. The Sapphire card take 2 slots, the HIS card only takes one. That's really the only difference between them.
    For a PSU, you'd be better off with: http://www.amazon.com/Corsair-430-Watt-Certified-Compatible-Platforms/dp/B004W2T2TM/ref=sr_1_33?s=pc&ie=UTF8&qid=1345122956&sr=1-33&keywords=power+supplies for only a few dollars more. PSUs are not a place to buy off-brand.
Nvidia Graphics Cards Graphics Product
