Hi, I just built a PC and it won't turn on. I got a job and worked for a
month to get this, and its a months salary down the drain so far , it's
about as good as paperweight right now, it's very depressing.
Anyways, I bought all the parts on newegg and followed the newegg video
tutorial on how to build a PC.
There are the parts I bought:
Case: NZXT Phantom PHAN-001WT White Steel / Plastic Enthusiast ATX Full
Tower Computer Case
CPU: AMD FX-8150 Zambezi 3.6GHz Socket AM3+ 125W Eight-Core Desktop
Processor FD8150FRGUBOX
PSU: Antec EarthWatts Green EA-380D Green 380W Continuous power ATX12V v2.3
/ EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply
Harddrive: SAMSUNG Spinpoint F4 HD322GJ/U 320GB 7200 RPM 16MB Cache SATA
3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
GPU: SAPPHIRE 100312-3L Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16
HDCP Ready CrossFireX Support Video Card
RAM: G.SKILL Ripjaws X Series 8GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
Desktop Memory Model F3-10666CL9S-8GBXL
Motherboard: ASRock 990FX Extreme3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD
Motherboard with UEFI BIOS
Here is a picture of my setup: http://imgur.com/a/KWFXt
The power supply is on (-) and is on, the power switch, reset switch Power
LED and HD LED plugs are on the right pins in the system header according to
the motherboard manual I followed. I have the 24 pin motherboard plug in,
the CPU plug in, the PCI-e plug in my graphics card which is in the PCI-e
slot, the HD audio header in the right place, the USB in the right place, my
GPU in the PCI-E slot, my ram in the memory slot, all compatible parts, my
AMD 8 core FX proccessor in the CPU area and my heatsink fan on top of it
although my heatsink fan won't snap on but that's a different story right
now. I might have pushed the heatsink fan too hard and crushed my proccessor
or something I don't know. I might have shorted the motherboard and
destroyed it, the power supply or the motherboard might have come in faulty.
I have no idea. Ive redone the system panel header plug various times just
to make sure.
I did a test boot before I built it following the newegg video but I didn't
know how to "short my power pins" I touched my screwdriver on the powerpins
but that didn't do anything so I just assumed I was doing it wrong and just
waited till I actually built it to see if the power button worked. Riht now
literally nothing is turning on when I press the power switch.
I need some advice, some help, what should I do? I don't want to take it to
a computer repair shop because they'll charge me a ridiculous price and
might replace the parts with different parts and might not even fix the
problems. I built a computer to avoid having to pay ridiculous price in the
first place. I have no idea whats wrong and its stresssing me out. Maybe I
was just in way over my head, I thought this would be easy.
I quite seriously want to kill myself right now. (First WOrld Problems )
Added note: The NZXT came with two different screw types that were labeled
for the motherboard, the standoffs and some other numered screws. I just
used the numbered screws instead and I don't know if that might have shorted
the motherboard or something? They seemed like they were made for the
motherboard, and perfectly fine, and they WERE labeled "motherboard".
Tower Computer Case
to make sure.
