Hooking up 8 fans to NZXT phantom fan controller?
I'm going to be purchasing 2 x 140mm Red LED case fans for the top, 1 x 120mm case fan for the front, 1 x 120mm case fan for the bottom, and 1 x 140mm case fan for the side. The case is a NZXT Phantom 820. I am wondering if it's possible to hook all the fan's up to the fan controller that comes with the case???? How would I do that, is there a tutorial?
2 answers Last reply
More about hooking fans nzxt phantom controller
  1. The phantom 630 has a fan controller that supports up to 10, it wouldn't surprise me if the 820 had the same one. The fan controller will be on the back of the motherboard tray, and they use 3 pin sockets.
  2. so what your tellin me is there is just 10 3 pin connecters just sittin there on the back of the motherboard tray?
Power Supplies Cases Fan Fan Controller Components
