CPU/Optical Drive: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1075005
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150616
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139040
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157297
HD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820227791
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146092
Is there anything you would change about this? I'm aiming for the ~$1300 range. Another GFX card? More RAM? What about a monitor?
