I'm currently using this fan:
230x230x20mm
http://www.techbuy.com.au/p/138108/COOLING_FANS_GREATERTHAN_120MM/ThermalTake/AF0047.asp
It just recentely started crapping out on me and I am looking for a replacement.
I am wondering if these will fit onto my computer:
230x200x30mm
http://www.frozencpu.com/products/14445/fan-935/BitFenix_Spectre_Pro_230mm_Fan_-_Blue_LED_BFF-LPRO-23030B-RP.html?tl=g36c331s1394#blank
and if the one above can't fit, the best alternative I found would be this one:
230x230x30mm
http://www.frozencpu.com/products/12875/fan-848/BitFenix_Spectre_LED_230mm_Fan_-_Blue_BFF-BLF-23030B-RP.html?tl=g36c331s1394#blank
Basically I need to know if either will fit, or if there are better options that I simply just couldn't find myself.
Thanks for any information given!
230x230x20mm
230x200x30mm
230x230x30mm
