First pc build help!
hi all iv been searching everywhere but im not sure what power supply should i get, iv done some test online that says between 300-500w but im not sure. can i have some feed back on which power supply should i get and any comments on my components if you wish on my first build. :) :) keep the price under 100 dollars please.
Lian Li Lancool Dark Armor PC-K62 $125.00
CoolerMaster Hyper 212 EVO CPU Cooler $35.00
LG GH24NS95 24x SATA DVD-RW Drive OEM $25.00
Corsair Vengeance 8GB (2x4GB) DDR3 $65.00
ASRock H77-PRO4-MVP Motherboard $95.00
Western Digital WD Green 500GB $59.00
Intel Core i3 3220
3 answers Last reply
More about first build help
  1. http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016 (semi modular)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027 ($30 after promo code and rebate)
    Onboard video doesn't require a high end power supply, but the two I listed will power many mid-range video cards, such as the 7850, if you upgrade.
  2. you are not getting a gpu?
  3. i am still deciding on what GPU i should get, any ideas? trying to keep under $150
Power Supplies Components Product
