Ok so I'm putting together a custom build and i need to know what case would work best for the components ill be filling it with, Also do i need Full tower or can i use a mid tower still??? i only ask because the 680 is like the lexington steele of VGC's
Motherboard - ASUS Sabertooth X79 2011
Graphics Card - GTX680 4096GB
Power Supply - 1000W 140mm Fan ATX Power Supply by KENTEK (is that good enough/compatible)
Water Cooler - Corsair Hydro Series Extreme Performance Liquid CPU Cooler H100i (Should i get a lesser model? I hear this is the best closed loop cooler but idk if its necessary...)
Im looking for a Black Case with a window and usb 3.0 ports (2 or more) around $100 but im willing to consider items high as $240 if its really worth it.
