First hello to everyone, as this is my first post here.
Now, few months ago I built a mid-range system, for graphic design purposes mainly, and not so much for gaming.
My apu of choice was AMD A6-3670k, because I'm old-time AMD customer, and from past experience I learned that I'll be getting the best value for given money.
However, one thing I never liked about AMDs, is their stock cooling system. It tends to be noisy in every generation of their CPUs, and it's the same with this processor.
I'm working in quiet environment mostly, and also my system is placed in the height of my head, when I'm sitting.
So the stock fan that came bundled with this processor heatsink, tends to be extremely noisy when CPU is under heavy load, and also it produces some kind of purring/clicking sound on higher speeds.
It's really starting to get on my nerves, so I want to change it, and if I'm already about to change fan, I will change the whole cooler.
So do you have any suggestion for aftermarket cooler equipped with standard AMD sockets clipping system, as I'm not really in mood of disassembling the whole system, just to put some fancy cooler.
And what do you think about this one from CM (I can get it for 20 pounds in local store):
http://www.coolermaster.com/product.php?product_id=6740
And generally, what are your experiences with those heat-pipes coolers. Do they really provide better cooling, or they are just another eye-candy marketing product.
