So my home built pc had been working perfectly for the 3-4 weeks i had it. worked fine yesterday and i shut it off and went to sleep. Next day it doesnt turn on when i press the power button. When opened the pc up and pushed down a lil on the 12 pin connector from the PSU to the motherboard the fans turn on and the lights for a split second. and it happens whenever i put pressure down.
@ first i thought it was my PSU so i put in my spare PSU an it did the same, except this time when i pressed the power button it turned on for a split second and turned off.
So the only thing that could be faulty is my power button or my MoBo but since the power button had a response so i guess its out of the question.
My question is if my MoBo is the problem? should i just get it replaced?
