Solved
Rendering problem?
I'm rendering a 10minute clip through sony vegas in 6mb/s 720p, it will randomly stop at any amount and i'll get a message saying "Display driver AMD has stopped working but has successfully recovered" but the rendering won't render any further, is this a graphics card issue?
Specs:
-AMD Phenom || x4 965
-8GB ddr3 RAM
-AMD Radeon 7770 GPU
-400w 80+ certified power supply
6 answers Last reply Best Answer
More about rendering problem
  1. No, it's probably a process that has a higher priority interrupting the video.
  2. I had nothing else running, although I just managed to fix the problem.
    I had GPU accelerated processing on, which took 100% GPU usage and crashed it(I think)
    It's all good now.
  3. Best answer
    That won't happen. GPU drivers are run in the kernel so nothing can interrupt them.
    It's all good now.
    GPU accelerated processing is nice but it's still a little buggy. Try updating your video drivers to see if they fixed whatever was causing the driver to crash.
  4. I just turned it off, I'm not even sure it makes a huge difference.
    I mean, I'm rather patient, I can wait a few extra minutes.
    Thanks for the reply though!
    Do you know where I can get the most recent drivers for AMD Radeon HD 7770?
  5. Best answer selected by connor12312.
    You're welcome. You can get the latest drivers here
    http://www2.ati.com/drivers/12-8_vista_win7_win8_64_dd_ccc.exe
    If that does not solve the problem you should do some research to see if it is a known software issue. If it is not a known software or driver issue it could point to a hardware flaw in your 7770 which may require a warranty replacement.
Radeon Rendering AMD Graphics
