Hey community....Need some help with final choices involving my new investment of a desktop PC!
I have pretty much the entire list of components that I'm going to be buying but would like a second opinion (and possibly an opinion on the case if everything should fit and what not). My budget is around 1000 to 1300 with monitor so I have a tight market to work with. I know little in the process of picking one brand over another so that would help as well.
I'm looking to build a computer to run smoothly Adobe Creative Suite 6 and have the capability of running Speed grade (requiring a better graphics card and so on). I would like to run smoothly, but as for a super machine I'm okay with staying around the specifics I have in my list...included is the CS6 system specs. And I will NOT be overclocking ever. The only video games I may play are Starcraft 2, and Diablo 3.
http://www.adobe.com/products/creativesuite/mastercollection/tech-specs.html
-ASUS P8H77-V LE Motherboard
-16GB Ram (Need help with specific brand and size)
-Intel Core i7 (Specifics would help here as well, what makes a 3.4 worse than a 3.5?)
-GeForce GTX 660 2GB
-SSD 120GB hard drive & 500 gig second hard drive
-Case...up in the air, would like a mix between open concept for air flow and price. LED lights don't excite me.
-Power supply 500w or 750w? (Is there a big different in buying a case that comes with a power supply versus a power supple and case separate?
-Heat sink?
-Also would need a blue tooth reader, wireless network adapter, standard CD burnable drive, Firewire connecters, USB readers....
Monitor is another big issue...I want an IPS display so It can be viewed from more than one angle, but i want a higher end monitor that can be capable of color correction as well as great color and brightness display so I can use/view color on the screen correctly when dealing with and editing raw footage.
I guess lets hear responses, what do you think I may need to do for changes? Anything you think is underpowered or I should upgrade? Lets hear it!
-Heat sink?
