CM Storm Stryker, Changing the power led?
Last response: in Components
I'm guessing it's the same as the trooper. It would be fairly easy - Just pop the top off, unscrew the front io panel and go nuts. Just make absolutely sure that you do not remove any cables, and if you do, mark them somehow. There's a ton of cables in that case.
Also if you are considering buying it, go for it. Best case I've ever had.
Yeah i love everything about the case, the only thing that turns me off is the red power led, if i can change it to white it would be golden.
Now i have no experience with this, how would i change the led's exactly
I saw what another person did , with ducttape lol..
http://www.overclock.net/t/1104349/the-official-cooler-...
but how would i get the other led's attached.
Would something like these work?
http://www.amazon.com/StarTech-com-Replacement-Power-Re...
For example, would i just cover the red led's with tape and jury rig the led's listed above on top of where the red ones were?
Would that be safe or even work? Would it affect the fan controller? ._.
Iff it is that simple, anyone know where i can find a white or blue version :I
