70c is a fine temp for a gpu to be at while under load...once its gets above 90c is when you should start to worry about it....some things you can do to lower your temps is clean the dust out of your system even remove the heatsink from the card and replace the thermal paste or download msi afterburner and set the fan profile higher so it spins the fans up higher to keep the temps even cooler
