Sign-in / Sign-up
Computer Parts Compatibility Check
  • Homebuilt
  • Computer
  • Systems
  • Product
Last response: in Systems
October 9, 2012 4:45:00 AM
Hello,
I'm building my first computer for gaming and video editing. I'm just wondering if everything looks compatible, I checked but it doesn't hurt for a second look over.
EVGA 04G-P4-2673-KR GeForce GTX 670 Superclocked: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Intel Core i7-3770K Ivy Bridge: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
MSI Z77A-G45 LGA 1155 Intel Z77 HDMI: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Western Digital WD AV-GP WD10EURX 1TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5": http://www.newegg.com/Product/Product.aspx?Item=N82E168...
COOLER MASTER Silent Pro Gold Series RSA00-80GAD3-US 1000W: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
LG Black 14X BD-R 2X BD-RE 16X DVD R 5X DVD-RAM 12X BD-ROM 4MB Cache SATA: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP : http://www.newegg.com/Product/Product.aspx?Item=N82E168...
G.SKILL Ripjaws Z Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) : http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Any advice and help is much appreciated!
More about : computer parts compatibility check
a b B Homebuilt system
October 9, 2012 5:38:27 AM
Change the psu,otherwise it's solid.
Look at seasonic or corsair.
m
l
a c 95 B Homebuilt system
October 9, 2012 11:49:56 AM
Also look at low profile ram; it won't collide with large heatsinks.
Other suggestion is maybe go to a 3570k and get an SSD. There shouldn't be too large a performance drop between them for video editing, and practically none for gaming.
m
l
October 9, 2012 12:06:58 PM
You could easily make do with a 500W PSU. On such an expensive system you don't want a green HDD, you want a SSD + normal HDD. I wonder if you really need the i7 either; on the other you didn't opt for 16 GB RAM.
m
l
October 9, 2012 2:19:08 PM
Thanks for the feedback. I took all of your advice to mind when I finished it up.
m
l
