Need help choosing PC parts for new build
  • New Build
  • Systems
Last response: in Systems
October 9, 2012 4:50:48 AM
Hey everyone.
I'm planning on building a desktop in the next week, and I'm trying to decide which setup I should go with. I want to try and build the cheapest possible desktop that I can build that will play most games at at least mostly medium settings at 1280 x 720 resolution (since my TV only supports up to 720p resolution.)
I want this desktop to last me at least a year without needing to upgrade parts, or get new parts due to parts breaking down and such, because I won't be upgrading for a very long time, since I don't have a lot of money to spare, so... here it goes.
These are the parts that I was originally going to go with and buy: (until I started thinking)
- AMD Phenom II X4 965 BE Quad Core @ 3.4GHz ($100)
- MSI 970A-G46 Socket AM3+ Motherboard ($85 - $10 Mail-In-Rebate)
- 4GB (2 x 2GB) G.SKILL Ripjaws X F3-12800CL9D-4GBXL DDR3-1600 ($24)
- ASUS NVIDIA GeForce GT 520 1GB GDDR3 Graphics Card (I already own this, and I realize this isn't a good graphics card for gaming, so don't tell me that)
- 100GB 5400RPM HDD (I already own this, and I can't remember what brand at the moment)
In total, ^^^ this setup ^^^ would cost me about $260-$270 after taxes, shipping, discounts and rebates.
OR, for a total of $300, I could upgrade the motherboard to a Gigabyte GA-990FXA-UD3 Socket AM3+ motherboard.
OR, for a total of $315, I could get myself a Cooler Master V6GT CPU cooler for the first setup (the MSI motherboard and the X4 CPU)
OR, for a total of $320, if I buy a cheaper CPU (the one I was looking at was an AMD Athlon X3 460) and keep the MSI motherboard, I could get myself a 500GB WD Blue 7200RPM HDD (and still have the 100GB HDD for extra) and upgrade to G.SKILL Sniper Series 8GB (2x4GB) DDR3 1333MHz CL9 Dual Channel Kit.
OR, for a total of $330, I could buy an AMD Phenom II X4 955 BE (which is still cheaper than the 965 BE,) and keep the MSI motherboard, I could get myself a 500GB WD Blue 7200RPM HDD (and still have the 100GB HDD for extra) and upgrade to G.SKILL Sniper Series 8GB (2x4GB) DDR3 1333MHz CL9 Dual Channel Kit.
More about : choosing parts build
October 9, 2012 4:59:52 AM
Go for an A10-5800K over a Phenom II 965 with an ATX A75 FM2 motherboard. $300 is an incredibly tricky budget to work with - you might want to up it to $450 / $500 to be on the safe side. That way you get a system that lasts far longer with fewer headaches and leaves you plenty of room for expansion.
Here's a sample configuration:
CPU: AMD A10-5800K 3.8GHz Quad-Core Processor ($124.99 @ Newegg Canada)
Motherboard: ASRock FM2A75 Pro4 ATX FM2 Motherboard ($99.99 @ NCIX)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory ($38.32 @ DirectCanada)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($54.03 @ Amazon Canada)
Video Card: Sapphire Radeon HD 7750 1GB Video Card ($107.99 @ Computer Valley)
Case: Antec One ATX Mid Tower Case ($29.99 @ NCIX)
Power Supply: Corsair Builder 500W 80 PLUS Certified ATX12V Power Supply ($39.99 @ Canada Computers)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($19.98 @ DirectCanada)
Total: $515.28
m
l
October 9, 2012 5:04:35 AM
every time I see a post suggesting the APU's not one lists 1866 memory. That's what these things were made to run. and because memory means everything to the types of processors i think you should get the fastest they support......... whether any benchmark proves me wrong or not.
m
l
October 9, 2012 5:10:17 AM
Total: $515.28
Problem is that I don't have over $500. I have about $330-$340 (that also includes taxes, shipping, etc) that I can spend, and I CAN'T go over that.
m
l
October 9, 2012 5:24:34 AM
That will not make any difference though. On default settings your motherboard runs the lowest speeds and timings that it can handle. I read the article with the chief AMD designer. But the speed differences between 1600 and 1866 are so minor that it's hard to notice.
m
l
October 9, 2012 5:48:36 AM
Quote:
do you have a case and psu?
Yes, I have a case and PSU.
Okay, so I've done a bit more thinking, and I'm now kind-of choosing between:
AMD Phenom II X4 965 BE Quad-Core @ 3.4GHz
G.SKILL Sniper Series (2 x 4GB) 8GB DDR3 1333MHz RAM
MSI 970A-G46 AM3/AM3+ Motherboard
500GB Western Digital 7200RPM Internal HDD
Total comes to $330 after taxes, shipping, rebates, etc.
OR
AMD Phenom II X4 955 BE Quad-Core @ 3.2GHz (200MHz slower CPU)
G.SKILL Ripjaws X Series (2 x 2GB) 4GB DDR3 1333MHz RAM (4GB less RAM)
Gigabyte GA-990FXA-UD3 Socket AM3/AM3+ Motherboard (more expensive motherboard)
500GB Western Digital 7200RPM Internal HDD (same HDD)
Total comes to $348 after taxes, shipping, rebates, etc.
How much better is the Gigabyte motherboard in comparison to the MSI motherboard?? Is it worth the extra $18 for a 200MHz slower CPU, 4GB less RAM, but a better motherboard (if it's a better one)?
m
l
October 9, 2012 5:56:27 AM
OR
Motherboard makes no difference in how your system performs. If you want to use newer hardware (USB 3, SATA 6, etc) then it's worth it but otherwise it isn't.
m
l
October 9, 2012 6:03:27 AM
Yes, I realize that the motherboard won't improve performance, but the MSI motherboard isn't as good, when it comes to build quality, as the Gigabyte motherboard, from what I've researched. However, I don't know how much of a difference that will make, which is why I was asking :p
Okay, how about this setup then:
100GB 5400RPM HDD (which I can use for my OS temporarily for now, since I have a 1TB external HDD which I can store my data on)
Total would come to about $315 after taxes, shipping, rebates, etc.
m
l
