Hi guys . I've basically built my first computer and I'm inthe process of plugging the cables in . Obviously plugging in the 24 pin ATX and 4 pin 12 v was easy . But a question about other components . Does it matter how these are connected as in I have plugged my ssd and cd drive into the same cable which supports up to 4 connections as ive seen. Seems to be sata right ? . This plugs into the power supply into any 6 pin socket as the cable itself has 6 pins ? And then my graphics card needs two power cables PCI-e . So I can plug two of these cables directly into the power supply in any 2 of the 4 provided 8 pin sockets on the power supply .? lol have I confused anybody yet . Basically I know what's going with what . I'm just asking does it matter how you plug these into the powe supply . If you guys need to ask me anything go ahead ..
Cheers
Cheers
