Sign-in / Sign-up
Help me to choose gfx card from these
  • Graphics Cards
  • Gtx
  • RAM
  • HD
  • Dual Core
  • Processors
  • Graphics
Last response: in Graphics Cards
August 17, 2012 4:40:36 PM
Which card is best.
HD 7750,HD 6790,HD 5770,GTX 550ti
I am totally confused.
PSU-500w
RAM-3gb
PciE-1.1
Processor-Dual core E7500
More about : choose gfx card
a b U Graphics card
August 18, 2012 5:21:50 AM
The 5770 should be dropped from consideration altogether, it's an old piece of hardware. The 7750 or the 6790 will be your best bet. They are both more powerful than the 550 Ti.
The 6790 is a little more powerful than the 7750, but the 7750 requires no extra power connectors. Just plug in and go.
Don't expect too much from a new graphics card though. Your CPU and motherboard are pretty old, so buying anything more than a 7750 will start to be bottlenecked by the CPU. So a new card will be a decent upgrade, but you'd need to a new build altogether to see a big performance increase.
m
l
