i have a rosewill stallion 500w psu and i want to upgrade as it is just not completing everyhting it should be doing.
case - rosewill challenger
mobo - msi 970a-g46
cpu - phenom ii x4 965 be
gpu - hd 7770
the cables are to short and some barely reach once i put the graphics card in (almost crushes it)
and for some reason whenever i plug it into the 3rd fan *large on on top inside of the case* nothing works at all as if it can't get power to it.
i can only get it to work with one screen at a time also as the other screen starts to give me the message that there is not enough power to display it.
can someone recommend a good power supply that is less then $100 and will complete my needs. I have room to crossfire and sli if i want to but chances are i won't so that isn't really necessary.
i do plan to overclock my cpu later though and will need a psu that can handle it.
mobo - msi 970a-g46
gpu - hd 7770
