I've been taking photos with digital cameras for years. I have never
seen this much problems with flash photos. It is something that
happens consistently - I have a set of test images and these date over
the entire life of the camera to date (6 weeks).
It's funny we are not seeing a lot of comment from Powershot A400
owners, either that or it is too new a model so far.
Archived from groups: rec.photo.digital.point+shoot (More info?)
"Rob J" <robj@nospam.nospam> wrote in message
news:4ddjg1lqqso0gc7f2h64vr43brqrlt06tr@4ax.com...
> See http://www.dcresource.com/forums/s [...] hp?t=11486 > and the attached pictures.
I have also had this problem with a Fuji digital camera, with flash but
mostly in very bright sunlight. I also came to the conclusion that it was
reflection, but felt that it was bright spots on the object being
photographed reflecting back at the camera. If the photo had the potential
of being really good, or passed around elsewhere, I removed the spots (or
should I say hid the spots?) by using the clone brush in Paint Shop Pro (by
JASC). I now use an Olympus, and have not had the problem in any light or
situation.
On Mon, 22 Aug 2005 18:43:50 GMT, "shee"
>> See http://www.dcresource.com/forums/s [...] hp?t=11486 >> and the attached pictures.
>situation.
>Sheila
How close to the lens is the flash unit on that camera? Your spots
don't seem to be consistent in location as they'd be with dust in or
on the lens. I've seen this phenomenon before when the flash and lens
are very close together and particles of airborne dust are floating
fairly near the camera. The light from the flash reflects back from
the dust particles to form blurry out of focus disks in the picture.
On Mon, 22 Aug 2005 18:44:44 -0500, Frank H. Emens <FEMENS@HIWAAY.NET>
>>> See http://www.dcresource.com/forums/s [...] hp?t=11486 >>> and the attached pictures.
>>situation.
>>Sheila
The lens and flash are very close together, in fact the flash is right
above the lens unit slightly to its left.
There is actually a warning in the manual about white dots appearing
on the picture, which it claims is a phenomenom that occurs with
digital cameras.
But I have been shooting with digital cameras for years and never saw
this problem on any other camera consistently like this one, which
suggests to me either a fault with this particular camera or design
fault - such as you suggest, the flash is too close to the lens.
I have in addition to this camera a Powershot S1 and this camera takes
flawless flash pictures, except for one day when the lens was dirty or
had rainspots on it - never saw that happen again, whereas the A400
has done it almost all the time.
>>situation.
>>Sheila
Comment from the retailer (a professional photo retailer rather than a
chain store) is that they have seen no other instances of this sort of
thing nor a rash of camera users coming in reporting similar problems.
If it is a design issue with this particular camera, I would have
expected to see more instances.
But as this is a basic point and shoot model it may be that the
typical user is a novice or someone who doesn't use the camera very
much and doesn't notice these things.
The retailer is very much on my side as is the law in this country -
so we wait for the next development. Right now my job is to take some
more photos to see if the problem is still occurring.
>>situation.
>>Sheila
But then there has to be a lot of dust around. None of these photos
were taken in dusty conditions.
There's always plenty of dust around; I'm sure you've noticed this when
a sunbeam enters a dark room. This observation also provides the clue to
a solution for your problem. Dust is more visible in low-light
conditions with a single strong light source, such as flash.
Try shooting in better lit conditions (turn on a light), use a larger
aperture (on the A400, I would test out the various scene modes,
especially portrait, night scene and indoor) and avoid the flash
whenever possible (if the above doesn't obviate the need for flash, use
a mini-tripod).
>a mini-tripod).
>Still not convinced?
>http://home.fujifilm.com/products/digital/tips/reflect/
Ah well. Pity, it's a very good camera for the money.
