Hey guys,
I'm wondering do you have any advice or resources that you use to check if the cable lengths included with the hardware will be enough to complete a build?
For example the power connections from PSU to motherboard or CD-rom? How can one figure out when to get extensions? And would you recommend to get the extension cables from the case manufacturer or just grab some generic ones from newegg if available?
Thanks in advance on anything you can contribute.
