Find my parts
mrapples74
27
I am learnng a lot about computer so i can build one. I can find the part to make a computer in my price range but it feels like overkill. though i can aford it i would like if i did not have to pay as much.
I have 1500 dollers to spend and i would like to run 3-4 monitor
The most damanding game i would like to play is battlefield 3 on high settings.
i would like it to be good for moives and multi tasking on the monitors
-i like intel mobo 1155
-dont know what kind of gpu amd or nvida
luciferano
1,513
http://pcpartpicker.com/p/k3d0
Check this out. It's the best that I could come up with at your budget for what you're asking for.
i5-2500K CPU $199.99@ NCIX http://pcpartpicker.com/part/intel-cpu-bx80623i52500k
Noctua NH-U12P SE2 CPU cooler $39.99@ NCIX http://pcpartpicker.com/part/noctua-cpu-cooler-nhu12pse2
MSI Z77A-GD55 motherboard $132.86 after shipping and MIR @ Newegg http://pcpartpicker.com/part/msi-motherboard-z77agd55
G.Skill F3-17000CL11D-8GBXL system Ram $39.99 after MIR @ Newegg http://pcpartpicker.com/part/gskill-memory-f317000cl11d8gbxl
Western Digital Caviar Blue WD10EZEX hard drive $80.75 @ NCIX http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex
Plextor PX-128M5S SSD $89.99 @ CompUSA http://pcpartpicker.com/part/plextor-internal-hard-drive-px128m5s
2x XFX FX-795A-TDJC $274.99 x2 after MIR @ Newegg http://pcpartpicker.com/part/xfx-video-card-fx795atdjc
Rosewill Redbone U3 ATX Mid-Tower case $42.50 after MIR @ Newegg http://pcpartpicker.com/part/rosewill-case-redboneu3
Antec EA-650 Green PSU $64.99 @ SuperBiiz http://pcpartpicker.com/part/antec-power-supply-ea650green
LG GH24NS90 DVD/CD reader and burner $16.99 @ Amazonhttp://pcpartpicker.com/part/lg-optical-drive-gh24ns90
Windows 7 x64 Pro $130.20$ Amazon http://pcpartpicker.com/part/microsoft-os-fqc04649
Logitech MX 5500 Revolution keyboard and mouse $134.99 @ Newegg http://pcpartpicker.com/part/logitech-keyboard-920000383
luciferano
1,513
Well, if you throw in another $100, you can get a higher capacity SSD such as the Vertex 4 256GB instead of the Plextor M5S 128GB that is in my current recommendation if you want to. It wouldn't help gaming performance, but you could put more on the SSD.
luciferano
1,513
What resolution do you want to play on? You say 3-4 displays, but not what resolution they'd be. Also, I recommend sticking with three, at least when you're playing games. Four would have bezels in the middle of your view and that's non-optimal for gaming.
luciferano
1,513
There is no on-board GPU. The CPU has an on-die GPU, but there's no GPU on the motherboard.
IDK if you can use the IGP of this system simultaneously with discrete graphics on the PCIe buses. If not, then you should be able to attache the fourth display to the graphics cards without a performance hit anyway or you could throw in a $30 or less graphics card for it.
http://pcpartpicker.com/part/gigabyte-video-card-gvr6451gi
Less than $20 (after MIR) for a 6450 is a great deal if that becomes necessary.
luciferano
1,513
You can do that, but it doesn't change anything from what I said. The GPU is on the CPU, not the motherboard, and the integrated GPU and the discrete GPUs might not work simultaneously.
If you want to change your motherboard, then you can do so; that board is compatible with this system. However, I recommend against buying such an expensive motherboard. It won't do much of anything that most cheaper boards can't do unless you're a suicide overclocker.
mrapples74
27
I want the better mobo for the Wi-Fi GO and other things for 50 doller more it does not sound that bad
and i dont think i would have to buy a cheap graphic card just to run 1 screen i would plung it into the HDMI port on the mobo
luciferano
1,513
A PCIe WiFi adapter would be cheaper and have superior performance and like I said, I'm not sure if you even can use the integrated graphics of that system when you are also using PCIe graphics. If you can, then don't worry about another card, but if you can't, then it is something to consider.
It's not that bad price-wise, but it's inferior unless there are other features that you will use.
Regardless, you don't need to justify your choices to me. It's your money, I wouldn't dare try to tell you what to do with it, I will only make recommendations. No matter what you choose to do, good luck to you in it.
