My custom built computer has been working fine for roughly a year and a half but a couple of days ago the monitor would go into power save mode after the windows logo. I tried my tv which said no signal. I uninstalled and reinstalled nvidia drivers countless times but the issue is still there. After i uninstall the drivers the computer boots fine for the first time then the same thing happens.I have done a clean install of nvidia. Safe mode works fine as im writing this from it.
Also ive tried to:
Remove the motherboard battery
Change the graphics card socket on the motherboard
I cleaned the graphics card
Also i went out and got a new graphics card still the same issue after the drivers are installed powersave comes on
I changed all the powersave options to never in the control pannel
If the graphics card is disabled through device manager the computer boots fine
My specs are:
AMD phenom II X4 945 processor 3.01GHz
4gb ram
64 bit windows ultimate
Nvidia geforce gt 240 graphics card
700W Power supply
Dell E193FP Monitor which i have for years and it has caused no problems
The replacement card i got is nvidia geforce g t620
Thanks in advance
Also ive tried to:
My specs are:
4gb ram
700W Power supply
Thanks in advance
