How to enable audio on ati radeon hd 4550
I have recently purchased a Hdmi (male) to Dvi male 25ft long cable - with the intention of getting video and audio on my LCD television, however that is not the case as i only get video - which is stunning btw.
how do i get audio ? do i do something additional or is it my graphics card (ATI Radeon HD 4550) does not support audio. I don't wanna spend unnecessary money.
please advise
Related ressources
jemm said:
Assuming you TV set has a HDMI connection, then just connect it to your video card through a HDMI cable for audio and video.
thank you for your response , however the graphics card has a DVI+VGA output and I purchased a DVI cable(male) to HDMI (male) hoping that I will get sound. do i need to have an attachment
Graphics card Master
Your graphic card needs to have an HDMI output to carry audio. If it does not have one, then you will need to connect the PC to the HDTV via other means for audio as well as the DVI to HDMI cable (for video).
-Wolf sends
Graphics card Authority
According to AMD, your card has an integrated DisplayPort technology, with audio, which is an innovative digital solution that supports the latest graphics and LCD technologies http://www.amd.com/br/products/desktop/graphics/ati-rad...
AMD also states that your card has HDMI® output support. It supports all display resolutions up to 1920x10802 -- Integrated HD audio controller with up to 2 channel 48 KHz stereo or multi-channel (7.1) AC3 enabling a plug-and-play cable-less audio solution http://www.amd.com/us/products/desktop/graphics/ati-rad...
DVI doesn't carry audio. You HAVE to use HDMI to HDMI to get audio, otherwise you have to go DVI for video and your sound card to the TV for audio. There is no way to get audio from DVI.
If your video card supports it, you can connect the SPDIF connector from the motherboard to the graphics card so it can use the audio in the HDMI.
But I'm not sure your card has this feature.
I am sure you meant to "connect the SPDIF connector from the motherboard" to your home theatre, or other audio device, and not to the "graphics card".
Ask the community
