Hi my name is paolo I'm pretty much confused about the 32 and 64bit specification. I'm confused if it is the CPU or the Motherboard.
First I tried to see if my CPU is 32 or 64bit. Ive seen a site that gives a few easy steps to determine if my CPU is 32 or 64bit.
#1 Go to Start -> Right click on Computer -> Click Properties. Click on Windows Experience Index ->View and Print detailed performance and system information.
mine shows like this.
System type 32-bit operating system
Number of processor cores 2
64-bit capable Yes
(Q: would this tell that my CPU is 64 bit and I'm just using 32-bit OS? or I just really got a 32 bit CPU? )
#2 Go to Start -> Type regedit
Browse to HKEY_LOCAL_MACHINE\HARDWARE\DESCRIPTION\System\CentralProcessor\0
they said : From ProcessorNameString you will be able to see the name of your processor and from Identifier you will see the family of the processor and if it has 64 then it is 64-bit capable.
mine is
Name: Intel(R) Core(TM)2 Duo CPU E4500 @2.20Ghz
Identifier: x86 family 6 model 15 stepping 13
(This one actually conclude that the cpu is 32-bit)
#3 Go to Start -> Type msinfo32.exe "System information"
check System type.
mine is x86-based PC
(Q: Is this x86 based PC is really identifying the CPU or the Motherboard? when i search on how to check if motherboard is 32 or 64bit this is what they do. So now I'm confused if it is for CPU or for Motherboard?)
#4 CPU-z
they said: Under Instructions from CPU tab, if you see EM64T (if its Intel) or AMD64 (if its AMD) then your processor is 64-bit capable.
I got EM64T which they said is 64-bit capable.
(Q: WHAT THE!! #1 I'm not sure, #2 and #3 said that my CPU is 32-bit but #4 said it is 64-bit please help me I'm really confused.)
64-bit capable Yes
mine is
check System type.
#4 CPU-z
