Cooler Master Elite 311 Air flow question
  • Power Supplies
  • Cooler Master
  • Cases
  • Fan
  • Elite
  • Components
Last response: in Components
February 25, 2013 4:59:01 AM
I have a Cooler Master Elite 311. I recently installed a Corsair H60 Hydrocool in my rig. And the only feasible place to mount the radiator fan combo is on my back exhaust port. I have installed it with the fan blowing air out(outside of case-fan exhuasting-Hydro radiator-inside of case) like the previous one was but this makes the fan pull air through the radiator from inside the case. Is this a bad thing or the way its supposed to work. Im thinking its the way its set up right. But i really want to know for sure. Also my side case fan is blowing in. So the front and side are blowing in and the back port is exhaust.
More about : cooler master elite 311 air flow question
February 25, 2013 10:48:39 PM
That is the correct way to set it up. Everything you describes seems right. No need to worry about anything
m
l
January 21, 2014 10:29:36 PM
I have the same case. I have installed fans like this
front fan - air in
side fan - air out
rear fan - air out
it works for me......
m
l
