Hi
I have a problem with my HAF 912 plus. This may be a noob question, but still I need help with this matter. I bought this case with 2 fans stock - front 200mm and back 120mm.
Now what I wanted to do was taking two old TT 1225 from my old Thermaltake V9 case and put them to front of HAF 912 plus and than mount the front 200mm as the upper fan (takin air out of the case).
And here is my problem - I can't find any screws which will fit to mount 200mm fan in the upper side of case. Tried every screw which came in with the case - no luck. Anyone tried to do it? Or is this 200mm fan meant for front only?
I couldn't mount the 120mm either - their screws were... to wide for haf 912 plus. I'm quite lost here.
