Ivy Bridge Build Help
I am looking for help/suggestions/critiques on a gaming build.
Approximate Purchase Date: December
Max budget: $1300 not including shipping and tax
System Usage: Gaming and surfing the web/movies
Parts Not Required: Keyboard, monitor, mouse and speakers
Current Monitor: Dell 2408 with 1920x1200 pixels resolution
Overclocking: Yes
SLI or Crossfire: Maybe
Country: USA
Vendor: Newegg, Amazon, and Fry's
What I want:
Gaming on max settings (BF3, Skyrim, CIV 5, etc)
Overclocking (4.5)
1 HDD for everything
1 SSD (Will get that in the future for OS and games)
MOBO Options:
P8Z77-V Pro $190
ASRock z77 Extreme4 $135
CPU: i5-3570K $230
RAM: Corsair Vengeance 8GB 1600Mhz Low Profile $40
PSU: Corsair TX750 V2 80+ $90 w/rebate
HDD: Samsung Spinpoint F3 1TB $85
CASE Options:
HAF 912 $50 w/rebate
CM 690 II Advanced $90
Corsair 400r $100
OS: Windows 7 Home Premium Full Version $180
Corsair H100 $110
CM Hyper 212 EVO $30
GPU: MSI R7950 Twin Frozr $305 w/rebate
4 answers Last reply
More about bridge build help
  1. This is a good build to go with and you can change some things on it but the cooler is defiantly one of the best out there.
    The Build
  2. Took some of your advice and changed the build up. But do you think I need a better cpu cooler than the CM Hyper 212+ to OC Ivy Bridge to 4.5Ghz?
    The Build: http://pcpartpicker.com/p/kaUs
  3. I have a question for you, is there a reason that you are going to get win7 full instead of just 64-bit?
  4. Thanks for noticing that before I made a mistake lol I meant to put the Windows 7 Home Premium 64-bit. Updated the build. Put the right version of windows 7 SP1, 750watt psu for future SLI. All for well under my budget $1160.53 :D
    The New Build:
Build Systems
